Amazon Echo Show 15 Camera Replacement
  1. Amazon Echo Show 15 Camera Replacement, Back Panel: step 1, image 1 of 3 Amazon Echo Show 15 Camera Replacement, Back Panel: step 1, image 2 of 3 Amazon Echo Show 15 Camera Replacement, Back Panel: step 1, image 3 of 3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
  2. Amazon Echo Show 15 Camera Replacement: step 2, image 1 of 3 Amazon Echo Show 15 Camera Replacement: step 2, image 2 of 3 Amazon Echo Show 15 Camera Replacement: step 2, image 3 of 3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
  3. Amazon Echo Show 15 Camera Replacement, Inner Black Panel: step 3, image 1 of 3 Amazon Echo Show 15 Camera Replacement, Inner Black Panel: step 3, image 2 of 3 Amazon Echo Show 15 Camera Replacement, Inner Black Panel: step 3, image 3 of 3
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
  4. Amazon Echo Show 15 Camera Replacement, Camera: step 4, image 1 of 3 Amazon Echo Show 15 Camera Replacement, Camera: step 4, image 2 of 3 Amazon Echo Show 15 Camera Replacement, Camera: step 4, image 3 of 3
    • Remove the small connector from the main device.
    • Disconnect the camera cord from the motherboard.
    • Pull the camera out of the main device.
    • The camera is connected to the main device with adhesive. You will need to use a bit more force to get it out.
Paysen Hudson
208 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 259
