Amazon Echo Show 2nd Gen Speaker Replacement
  1. Amazon Echo Show 2nd Gen Speaker Replacement, Sound Card: step 1, image 1 of 3 Amazon Echo Show 2nd Gen Speaker Replacement, Sound Card: step 1, image 2 of 3 Amazon Echo Show 2nd Gen Speaker Replacement, Sound Card: step 1, image 3 of 3
    • Unscrew the white case using the TR1 screwdriver bit to remove the 4mm screws.
    • Pull on the top until the case becomes fully dislodged.
  2. Amazon Echo Show 2nd Gen Speaker Replacement: step 2, image 1 of 2 Amazon Echo Show 2nd Gen Speaker Replacement: step 2, image 2 of 2
    • Pull out the two white plugs by firmly grasping them and pulling in a downward motion until they become disconnected.
  3. Amazon Echo Show 2nd Gen Speaker Replacement: step 3, image 1 of 1
    • Unscrew the 4mm, red-marked screws with the TR6 screwdriver bit.
    • Detach the ribbon from the circuit board by grasping from the top of the ribbon and pulling away from the board.
  4. Amazon Echo Show 2nd Gen Speaker Replacement: step 4, image 1 of 3 Amazon Echo Show 2nd Gen Speaker Replacement: step 4, image 2 of 3 Amazon Echo Show 2nd Gen Speaker Replacement: step 4, image 3 of 3
    • Unscrew the red-marked, 4mm screws with the J1 screwdriver bit.
    • Carefully slide the sound card up and out of the black casing.
  5. Amazon Echo Show 2nd Gen Speaker Replacement, Speakers: step 5, image 1 of 3 Amazon Echo Show 2nd Gen Speaker Replacement, Speakers: step 5, image 2 of 3 Amazon Echo Show 2nd Gen Speaker Replacement, Speakers: step 5, image 3 of 3
    • Firmly grasp the white trim of the front piece with one hand while the other pulls back on the black back portion of the device.
  6. Amazon Echo Show 2nd Gen Speaker Replacement: step 6, image 1 of 2 Amazon Echo Show 2nd Gen Speaker Replacement: step 6, image 2 of 2
    • Unscrew all the indicated screws with the screwdriver.
    • Carefully remove the plate from the device.
  7. Amazon Echo Show 2nd Gen Speaker Replacement: step 7, image 1 of 3 Amazon Echo Show 2nd Gen Speaker Replacement: step 7, image 2 of 3 Amazon Echo Show 2nd Gen Speaker Replacement: step 7, image 3 of 3
    • After unscrewing the speakers, gently pull out the foam covered attachment indicated in the orange box.
  8. Amazon Echo Show 2nd Gen Speaker Replacement: step 8, image 1 of 1
    • Insert the white circuit box into the back plate the old speaker was removed from as indicated in he orange box.
    • Repeat on the other speaker if needed.
2 Comments
Where do I get replacement speakers at?
John Henry - Reply
These instructions are missing one important step, at least on my version of the Echo Show 10 2nd gen. There are 8 Tr8 screws holding the big black backside with the speakers + sound card in place 4 at the top, 2 on each side and 2 at the bottom. Note the 2 screws at the bottom are behind the white cover removed in step 1.
These 8 screws need to be removed before separating the back from the front in Step 5 of this guide.
Note the white cover is not only attached with 6 tr1 screws there also is some double-sided tape holding it in place at the edge near the power-connector you can see the tape remains at the first Picture of step 3 of the Sound Card replacement guide.
Hans de Goede - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 26
All Time: 808
