Amazon Echo Show Back Cover Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Amazon Echo Show Back Cover Replacement, Back Cover: step 1, image 1 of 2 Amazon Echo Show Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Using your hands, gently remove the taped-in rubber foot from device.
  2. Amazon Echo Show Back Cover Replacement: step 2, image 1 of 2 Amazon Echo Show Back Cover Replacement: step 2, image 2 of 2
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
  3. Amazon Echo Show Back Cover Replacement: step 3, image 1 of 1
    • After the screws are removed, grip the front panel and remove, using a plastic opening tool if necessary. This will expose the inside of the device.
  4. Amazon Echo Show Back Cover Replacement: step 4, image 1 of 2 Amazon Echo Show Back Cover Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Repeat this step for the other speaker, and lay the front section flat with the facing down.
    • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
2 Comments
this particular guide originally only had the prerequisite guide portion, so the steps to replace the top buttons were repeated across every single guide we had. I adjusted the prerequisite guide to include the separation of the two halves and moved the top button replacement guide to its own page. As this is still a private guide, it won’t be published unless we approve it.
Justin Williams - Reply
This article has been flagged as the prerequisite guide for a few of our articles, so I ended up altering it to be such. However, the ones that are not linked to this one, I added a few steps.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 404
