Amazon Fire HD 10 Front Facing Camera Replacement
  1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: step 1, image 1 of 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: step 1, image 2 of 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: step 1, image 3 of 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Front Facing Camera Replacement: step 2, image 1 of 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Front Facing Camera Replacement: step 3, image 1 of 2 Amazon Fire HD 10 Front Facing Camera Replacement: step 3, image 2 of 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Front Facing Camera Replacement: step 4, image 1 of 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 1 of 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 2 of 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 3 of 3
    • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
    • Make sure you place the screws in a safe location nearby.
  6. Amazon Fire HD 10 Front Facing Camera Replacement: step 6, image 1 of 2 Amazon Fire HD 10 Front Facing Camera Replacement: step 6, image 2 of 2
    • Lift the black plastic cover once the screws are removed.
    • Place aside for later reassembly.
  7. Amazon Fire HD 10 Front Facing Camera Replacement: step 7, image 1 of 2 Amazon Fire HD 10 Front Facing Camera Replacement: step 7, image 2 of 2
    • Detach the connector using a plastic opening tool or spudger.
    • The camera is still connected to the motherboard.
  8. Amazon Fire HD 10 Front Facing Camera Replacement: step 8, image 1 of 2 Amazon Fire HD 10 Front Facing Camera Replacement: step 8, image 2 of 2
    • Grip the camera and lift up to detach the ZIF connector from the motherboard.
Jaie Hillery
1,718 Reputation
10 Guides authored
USF Tampa, Team 16-6, Blackwell Winter 2016 Member of USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Members
22 Guides authored
One Comment
Can this camera module be upgraded with a better version?
Jimmy Kee - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,151
