Amazon Fire HD 10 Rear Facing Camera Replacement
  1. Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: step 1, image 1 of 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: step 1, image 2 of 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: step 1, image 3 of 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Rear Facing Camera Replacement: step 2, image 1 of 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Rear Facing Camera Replacement: step 3, image 1 of 2 Amazon Fire HD 10 Rear Facing Camera Replacement: step 3, image 2 of 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Rear Facing Camera Replacement: step 4, image 1 of 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: step 5, image 1 of 2 Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: step 5, image 2 of 2
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  6. Amazon Fire HD 10 Rear Facing Camera Replacement: step 6, image 1 of 2 Amazon Fire HD 10 Rear Facing Camera Replacement: step 6, image 2 of 2
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  7. Amazon Fire HD 10 Rear Facing Camera Replacement: step 7, image 1 of 2 Amazon Fire HD 10 Rear Facing Camera Replacement: step 7, image 2 of 2
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
2 other people completed this guide.
Jaie Hillery
1,718 Reputation
10 Guides authored
USF Tampa, Team 16-6, Blackwell Winter 2016 Member of USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Members
22 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 896
