Amazon Fire HD 10 Screen Replacement
  1. Amazon Fire HD 10 Screen Replacement, Screen: step 1, image 1 of 3 Amazon Fire HD 10 Screen Replacement, Screen: step 1, image 2 of 3 Amazon Fire HD 10 Screen Replacement, Screen: step 1, image 3 of 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: step 2, image 1 of 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: step 3, image 1 of 2 Amazon Fire HD 10 Screen Replacement: step 3, image 2 of 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: step 4, image 1 of 1
    • Remove the screen and digitizer from the case completely.
27 other people completed this guide.
Jaie Hillery
1,762 Reputation
10 Guides authored
USF Tampa, Team 16-6, Blackwell Winter 2016 Member of USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Members
22 Guides authored
17 Guide Comments
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Reply
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Reply
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Reply
What is needed to attach the screen back to the case?
Jimmy Lee - Reply
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 135
All Time: 39,087
