Amazon Fire HD 8 12th Gen USB Port Replacement
  1. Amazon Fire HD 8 12th Gen USB Port Replacement, Buttons: step 1, image 1 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement, Buttons: step 1, image 2 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement, Buttons: step 1, image 3 of 3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
  2. Amazon Fire HD 8 12th Gen USB Port Replacement: step 2, image 1 of 2 Amazon Fire HD 8 12th Gen USB Port Replacement: step 2, image 2 of 2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
  3. Amazon Fire HD 8 12th Gen USB Port Replacement, Battery: step 3, image 1 of 2 Amazon Fire HD 8 12th Gen USB Port Replacement, Battery: step 3, image 2 of 2
    • Using the iFixit opening tool, disconnect the battery from the circuit board.
  4. Amazon Fire HD 8 12th Gen USB Port Replacement: step 4, image 1 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 4, image 2 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 4, image 3 of 3
    • Slowly and gently, pull and remove the 3 adhesives under the old battery.
    • Remove all 3 by pulling the adhesive, signified by a black flap with white adhesive. You will know it is removed when the adhesive has come out from under the battery and you are now able to move the battery.
  5. Amazon Fire HD 8 12th Gen USB Port Replacement: step 5, image 1 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 5, image 2 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 5, image 3 of 3
    • Remove the old battery from the device using the opening tool.
    • If necessary, clean under your old battery and then insert the new battery with new adhesive to ensure the battery stays in place.
  6. Amazon Fire HD 8 12th Gen USB Port Replacement, USB Port: step 6, image 1 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement, USB Port: step 6, image 2 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement, USB Port: step 6, image 3 of 3
    • Remove the yellow-orange strip from the back of the device by disconnecting it from the motherboard.
    • Disconnect the black wiring on the motherboard.
  7. Amazon Fire HD 8 12th Gen USB Port Replacement: step 7, image 1 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 7, image 2 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 7, image 3 of 3
    • Unscrew the motherboard from the device. 7 Screws total should be unscrewed. (0+ screwhead used from iFixit tool kit. 2.5 mm screw)
    • Disconnect the front camera from the motherboard by disconnecting the yellow orange strip.
  8. Amazon Fire HD 8 12th Gen USB Port Replacement: step 8, image 1 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 8, image 2 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 8, image 3 of 3
    • Once the motherboard is fully disconnected from the device, lift and remove the motherboard from the device using an opening tool.
    • Heat up the motherboard area under the usb/charging ports using a soldering iron or hair dryer. (Connection ports)
    • Be careful of the hot metal and hot tools being used.
  9. Amazon Fire HD 8 12th Gen USB Port Replacement: step 9, image 1 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 9, image 2 of 3 Amazon Fire HD 8 12th Gen USB Port Replacement: step 9, image 3 of 3
    • Once area is heated, gently pull the charging port while still heating the connection ports.
    • The charging port should come out its position and be ready to be replaced.
    • Be careful of hot metal and hot tools.
Jaden Palmer
485 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 913
