Amazon Fire HD 8 Screen Replacement
  1. Amazon Fire HD 8 Screen Replacement, Screen: step 1, image 1 of 2 Amazon Fire HD 8 Screen Replacement, Screen: step 1, image 2 of 2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Screen Replacement: step 2, image 1 of 1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Screen Replacement: step 3, image 1 of 3 Amazon Fire HD 8 Screen Replacement: step 3, image 2 of 3 Amazon Fire HD 8 Screen Replacement: step 3, image 3 of 3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Screen Replacement: step 4, image 1 of 3 Amazon Fire HD 8 Screen Replacement: step 4, image 2 of 3 Amazon Fire HD 8 Screen Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
28 other people completed this guide.
Dan Shimkus
1,229 Reputation
3 Guides authored
USF Tampa, Team 1-3, Leahy Spring 2016 Member of USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 Members
17 Guides authored
19 Guide Comments
Thankyou so much!
Judie Buder @me.com - Reply Share
Very nice, but even Amazon is not marketing the replacement screens.
Wendy Huntington Parker Fages - Reply Share
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Kelsea Weber - Share
Fingers crossed Amazon offers more parts in the future! :)
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
Kitty Morgan - Share
Past 24 Hours: 12
Past 7 Days: 52
Past 30 Days: 237
All Time: 75,687
