Amazon Fire Phone Headphone Jack Replacement
  1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: step 1, image 1 of 1
    • If the display is damaged use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: step 2, image 1 of 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: step 2, image 2 of 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: step 2, image 3 of 3
    • Power off your phone.
    • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: step 3, image 1 of 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: step 3, image 2 of 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: step 3, image 3 of 3
    • Press the single suction cup just above the home button.
    • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
  4. Amazon Fire Phone Headphone Jack Replacement: step 4, image 1 of 3 Amazon Fire Phone Headphone Jack Replacement: step 4, image 2 of 3 Amazon Fire Phone Headphone Jack Replacement: step 4, image 3 of 3
    • Remove the 1mm screw concealed in the headphone jack.
    • Afterwards the headphone jack will easily pop off.
2 other people completed this guide.
Savannah Moen
237 Reputation
1 Guide authored
Cal Poly, Team 5-7, Maness Fall 2015 Member of Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
5 Members
10 Guides authored
One Comment
hello sir i need amazon fire back casing in Pakistan
Kashif Arif - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,869
