Amazon Fire Phone Micro-USB Port Replacement
Kent Kawahara
Kent Kawahara and 4 other contributors
Last updated on March 21, 2018
40 minutes - 1 hour
Very difficult
Introduction
Go to step 1
Note that before removing the Micro-USB port you will need to remove the battery.
Tools
Show more…
  1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: step 1, image 1 of 1
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: step 2, image 1 of 3 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: step 2, image 2 of 3 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: step 2, image 3 of 3
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Micro-USB Port Replacement: step 3, image 1 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 3, image 2 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 3, image 3 of 3
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: step 4, image 1 of 1
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
  5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: step 5, image 1 of 1
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
  6. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: step 6, image 1 of 2 Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: step 6, image 2 of 2
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
  7. Amazon Fire Phone Micro-USB Port Replacement: step 7, image 1 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 7, image 2 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 7, image 3 of 3
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
  8. Amazon Fire Phone Micro-USB Port Replacement: step 8, image 1 of 1
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
  9. Amazon Fire Phone Micro-USB Port Replacement: step 9, image 1 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 9, image 2 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 9, image 3 of 3
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
  10. Amazon Fire Phone Micro-USB Port Replacement: step 10, image 1 of 2 Amazon Fire Phone Micro-USB Port Replacement: step 10, image 2 of 2
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
  11. Amazon Fire Phone Micro-USB Port Replacement: step 11, image 1 of 1
    • Lift off bottom plastic piece with flat antenna cables
3 other people completed this guide.
Kent Kawahara
110 Reputation
1 Guide authored
Cal Poly, Team 5-7, Maness Fall 2015 Member of Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
5 Members
10 Guides authored
2 Comments
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,488
