Amazon Fire TV Cube Motherboard Replacement
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: step 1, image 1 of 3 Amazon Fire TV Cube Motherboard Replacement, Speaker: step 1, image 2 of 3 Amazon Fire TV Cube Motherboard Replacement, Speaker: step 1, image 3 of 3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: step 2, image 1 of 3 Amazon Fire TV Cube Motherboard Replacement: step 2, image 2 of 3 Amazon Fire TV Cube Motherboard Replacement: step 2, image 3 of 3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: step 3, image 1 of 1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: step 4, image 1 of 2 Amazon Fire TV Cube Motherboard Replacement: step 4, image 2 of 2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: step 5, image 1 of 2 Amazon Fire TV Cube Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: step 6, image 1 of 2 Amazon Fire TV Cube Motherboard Replacement: step 6, image 2 of 2
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: step 7, image 1 of 2 Amazon Fire TV Cube Motherboard Replacement: step 7, image 2 of 2
    • Gently pry the motherboard up and off.
3 other people completed this guide.
2 Comments
where do you buy the mother board ?
Sam Handa - Reply
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
futuregu - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,661
