Amazon Fire TV Cube Speaker Replacement
  1. Amazon Fire TV Cube Speaker Replacement, Speaker: step 1, image 1 of 3 Amazon Fire TV Cube Speaker Replacement, Speaker: step 1, image 2 of 3 Amazon Fire TV Cube Speaker Replacement, Speaker: step 1, image 3 of 3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Speaker Replacement: step 2, image 1 of 3 Amazon Fire TV Cube Speaker Replacement: step 2, image 2 of 3 Amazon Fire TV Cube Speaker Replacement: step 2, image 3 of 3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Speaker Replacement: step 3, image 1 of 1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Speaker Replacement: step 4, image 1 of 2 Amazon Fire TV Cube Speaker Replacement: step 4, image 2 of 2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
2 other people completed this guide.
One Comment
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
Lee - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 3,290
