Amazon Fire TV Stick Remote Motherboard Replacement
  1. Amazon Fire TV Stick Remote Motherboard Replacement, Remote Motherboard: step 1, image 1 of 3 Amazon Fire TV Stick Remote Motherboard Replacement, Remote Motherboard: step 1, image 2 of 3 Amazon Fire TV Stick Remote Motherboard Replacement, Remote Motherboard: step 1, image 3 of 3
    • Use a plastic opening tool to open the battery cover. Apply a small amount of force into the crease.
    • Remove batteries.
  2. Amazon Fire TV Stick Remote Motherboard Replacement: step 2, image 1 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 2, image 2 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to pry off the top black ring.
  3. Amazon Fire TV Stick Remote Motherboard Replacement: step 3, image 1 of 2 Amazon Fire TV Stick Remote Motherboard Replacement: step 3, image 2 of 2
    • Remove the 6mm triangle head screw on the front of the remote.
  4. Amazon Fire TV Stick Remote Motherboard Replacement: step 4, image 1 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 4, image 2 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 4, image 3 of 3
    • Use two plastic opening tools to pry along the seam of the remote and separate the face plate.
  5. Amazon Fire TV Stick Remote Motherboard Replacement: step 5, image 1 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 5, image 2 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 5, image 3 of 3
    • Lift the rubber pad from the motherboard.
  6. Amazon Fire TV Stick Remote Motherboard Replacement: step 6, image 1 of 2 Amazon Fire TV Stick Remote Motherboard Replacement: step 6, image 2 of 2
    • Use the opening tool to lift the back of the motherboard. Slowly lift the motherboard while keeping the wires straight.
12 other people completed this guide.
Andrew Busse
915 Reputation
2 Guides authored
IUPUI, Team 2-3, Harley SU 2016 Member of IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Members
14 Guides authored
9 Guide Comments
It hasnt worked from the start dissapointed
Doug Marriott - Reply
Hasnt worked from start dissaopointing product
I have had this firestick for quite some time it's something happened it would me put my password in I forgot it and it says no signal what do I do
CINDY BROWN - Reply
My firestick wen I plugin any tv it's not detecting n says no signal
Philip Nunes - Reply
My firestick wen I put in any of the hdmi port it doesn't detect any of my tv blank screen n no signal can u let me know
Past 24 Hours: 10
Past 7 Days: 73
Past 30 Days: 196
All Time: 35,147
