AmazonBasics BTV1 Battery Replacement
  1. AmazonBasics BTV1 Battery Replacement, Battery: step 1, image 1 of 2 AmazonBasics BTV1 Battery Replacement, Battery: step 1, image 2 of 2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Battery Replacement: step 2, image 1 of 2 AmazonBasics BTV1 Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Battery Replacement: step 3, image 1 of 2 AmazonBasics BTV1 Battery Replacement: step 3, image 2 of 2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Battery Replacement: step 4, image 1 of 2 AmazonBasics BTV1 Battery Replacement: step 4, image 2 of 2
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Battery Replacement: step 5, image 1 of 2 AmazonBasics BTV1 Battery Replacement: step 5, image 2 of 2
    • Lift the motherboard off the face plate, exposing the battery.
    • Lift the battery out of its housing.
    • Use caution when using tools around the battery; batteries can be dangerous if punctured.
10 other people completed this guide.
Chris Shannon
1,039 Reputation
5 Guides authored
USF Tampa, Team 14-2, Lacy Spring 2016 Member of USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Members
5 Guides authored
8 Comments
donde consigo la bateria?
bnet_d72 - Reply
Nice job, Chris! Thank you.
David Printz - Reply
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - Reply
Need information on where to get a replacement battery!
dan - Reply
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 3,069
