AmazonBasics BTV1 Speaker Replacement
  1. AmazonBasics BTV1 Speaker Replacement, Speaker: step 1, image 1 of 2 AmazonBasics BTV1 Speaker Replacement, Speaker: step 1, image 2 of 2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Speaker Replacement: step 2, image 1 of 2 AmazonBasics BTV1 Speaker Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Speaker Replacement: step 3, image 1 of 2 AmazonBasics BTV1 Speaker Replacement: step 3, image 2 of 2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Speaker Replacement: step 4, image 1 of 2 AmazonBasics BTV1 Speaker Replacement: step 4, image 2 of 2
    • Gently pull the two plastic connectors from the motherboard.
    • Lift the front panel of the case and remove the speakers.
2 other people completed this guide.
Chris Shannon
1,039 Reputation
5 Guides authored
USF Tampa, Team 14-2, Lacy Spring 2016 Member of USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Members
5 Guides authored
One Comment
Where do you get replacement speakers? What kind?
laurieshorter - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,955
