Analogue Pocket Battery Replacement
  1. Analogue Pocket Battery Replacement, Prepare your device for disassembly: step 1, image 1 of 3 Analogue Pocket Battery Replacement, Prepare your device for disassembly: step 1, image 2 of 3 Analogue Pocket Battery Replacement, Prepare your device for disassembly: step 1, image 3 of 3
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
  2. Analogue Pocket Battery Replacement, Unfasten the battery shell: step 2, image 1 of 2 Analogue Pocket Battery Replacement, Unfasten the battery shell: step 2, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Battery Replacement, Remove the battery shell: step 3, image 1 of 3 Analogue Pocket Battery Replacement, Remove the battery shell: step 3, image 2 of 3 Analogue Pocket Battery Replacement, Remove the battery shell: step 3, image 3 of 3
  4. Analogue Pocket Battery Replacement, Disconnect the battery: step 4, image 1 of 2 Analogue Pocket Battery Replacement, Disconnect the battery: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Battery Replacement, Remove the battery: step 5, image 1 of 3 Analogue Pocket Battery Replacement, Remove the battery: step 5, image 2 of 3 Analogue Pocket Battery Replacement, Remove the battery: step 5, image 3 of 3
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
164,541 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,271 Guides authored
2 Guide Comments
So where does one find the replacement battery? Can't find one anywhere?!?
Jonathan Smookler - Reply Share
Great guide, but there are no replacement batteries for sale
Bart Mlotkowski - Reply Share
Past 24 Hours: 33
Past 7 Days: 74
Past 30 Days: 243
All Time: 6,020
