Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement
  1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: step 1, image 1 of 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: step 1, image 2 of 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: step 1, image 3 of 3
    • Complete this step to reduce the risk of burns, fire, electric shock, or injury.
    • Turn the control on the trimmers to "off".
    • Remove the plug from the electrical outlet.
  2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: step 2, image 1 of 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: step 2, image 2 of 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: step 2, image 3 of 3
    • Remove the two blade screws from the top blade of the trimmer.
  3. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: step 3, image 1 of 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: step 3, image 2 of 2
    • Lift the top blade from the device.
    • The bottom blade is attached, but not secured, to the underside of the top blade.
  4. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: step 4, image 1 of 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: step 4, image 2 of 2
    • Flip the top blade over.
    • Lift the bottom blade from the top blade.
  5. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: step 5, image 1 of 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: step 5, image 2 of 2
    • Clean or lubricate the device if necessary.
2 other people completed this guide.
David Taylor
151 Reputation
1 Guide authored
USF Tampa, Team 1-34, Donnelly Fall 2014 Member of USF Tampa, Team 1-34, Donnelly Fall 2014
USFT-DONNELLY-F14S1G34
1 Member
1 Guide authored
One Comment
Trying to find out how to sharpen. Blades are so expensive. $ 24 per pack.
I cut my hair every two weeks. Then dull blades.
I'd invest in some type of sharpening tool. ( Not sand paper ).
rslau13@gmail.com
Map daddy - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 43
All Time: 6,792
