Android tablet Nobis NB09 Screen Replacement
  1. Android tablet Nobis NB09 Screen Replacement, Screen: step 1, image 1 of 3 Android tablet Nobis NB09 Screen Replacement, Screen: step 1, image 2 of 3 Android tablet Nobis NB09 Screen Replacement, Screen: step 1, image 3 of 3
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
  2. Android tablet Nobis NB09 Screen Replacement: step 2, image 1 of 3 Android tablet Nobis NB09 Screen Replacement: step 2, image 2 of 3 Android tablet Nobis NB09 Screen Replacement: step 2, image 3 of 3
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
  3. Android tablet Nobis NB09 Screen Replacement: step 3, image 1 of 3 Android tablet Nobis NB09 Screen Replacement: step 3, image 2 of 3 Android tablet Nobis NB09 Screen Replacement: step 3, image 3 of 3
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
  4. Android tablet Nobis NB09 Screen Replacement: step 4, image 1 of 3 Android tablet Nobis NB09 Screen Replacement: step 4, image 2 of 3 Android tablet Nobis NB09 Screen Replacement: step 4, image 3 of 3
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
4 other people completed this guide.
Enea Osmann
158 Reputation
1 Guide authored
2 Guide Comments
The digitizer replacement instructions was great. Thanks
steven warren - Reply
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,605
