Anker 2.4G Wireless Mouse LED Replacement
  1. Anker 2.4G Wireless Mouse LED Replacement, LED: step 1, image 1 of 1
    • Use a spudger to gently pry off the stickers to reveal the location of the four screws.
  2. Anker 2.4G Wireless Mouse LED Replacement: step 2, image 1 of 1
    • Remove the four screws to continue.
  3. Anker 2.4G Wireless Mouse LED Replacement: step 3, image 1 of 2 Anker 2.4G Wireless Mouse LED Replacement: step 3, image 2 of 2
    • Pry the center of the mouse apart using a spudger to separate the upper and lower housing of the boards.
  4. Anker 2.4G Wireless Mouse LED Replacement: step 4, image 1 of 1
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse LED Replacement: step 5, image 1 of 2 Anker 2.4G Wireless Mouse LED Replacement: step 5, image 2 of 2
    • Take the upper housing of the mouse and remove the two screws that hold the board in place.
  6. Anker 2.4G Wireless Mouse LED Replacement: step 6, image 1 of 1
    • Gently remove the circuit board from the mouse.
  7. Anker 2.4G Wireless Mouse LED Replacement: step 7, image 1 of 1
    • To remove the LED, flip the board over and desolder the wires.
    • Replace LED with a new LED and resolder into place.
Colin
406 Reputation
3 Guides authored
Cal Poly, Team 1-39, Maness Winter 2014 Member of Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 7
All Time: 3,214
