Anker 2.4G Wireless Mouse Scroll Wheel Replacement
  1. Anker 2.4G Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 1
    • Remove the stickers from the bottom of the mouse to have access to the screws, The stickers are shown in the picture by the red rectangles.
  2. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: step 2, image 1 of 1
    • Use a Phillips #00 to remove the 4 screws shown by the red circles in the picture.
  3. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: step 3, image 1 of 2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: step 3, image 2 of 2
    • Using a plastic opening tool or spudger, on the center of the mouse, separate the upper and lower board.
  4. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: step 4, image 1 of 1
    • Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse. Avoid pulling the wires too hard to prevent them from breaking.
    • Don't pull the wires too hard, as they might break.
  5. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: step 5, image 1 of 2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: step 5, image 2 of 2
    • Pull the scroll wheel put parallel to the board.
    • This may take some force to remove. Pull the scroll wheel out parallel to the board rather than perpendicular to it.
    • Replace/clean if needed.
    • If your mouse still does not work after this step, then continue to the next instruction.
  6. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: step 6, image 1 of 1
    • Desolder the three pins, then solder in the replacement part.
Vincent Lee
361 Reputation
3 Guides authored
Cal Poly, Team 1-39, Maness Winter 2014 Member of Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Members
16 Guides authored
One Comment
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 58
All Time: 8,565
