Anker SoundCore 2 Charging Port Replacement
  1. Anker SoundCore 2 Charging Port Replacement, Front Panel: step 1, image 1 of 2 Anker SoundCore 2 Charging Port Replacement, Front Panel: step 1, image 2 of 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Charging Port Replacement, Motherboard: step 2, image 1 of 3 Anker SoundCore 2 Charging Port Replacement, Motherboard: step 2, image 2 of 3 Anker SoundCore 2 Charging Port Replacement, Motherboard: step 2, image 3 of 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Charging Port Replacement: step 3, image 1 of 3 Anker SoundCore 2 Charging Port Replacement: step 3, image 2 of 3 Anker SoundCore 2 Charging Port Replacement: step 3, image 3 of 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
  4. Anker SoundCore 2 Charging Port Replacement, Charging Port: step 4, image 1 of 2 Anker SoundCore 2 Charging Port Replacement, Charging Port: step 4, image 2 of 2
    • Desolder the charging port from the motherboard and solder a new one on.
    • For help with soldering and desoldering, follow this guide.
5 other people completed this guide.
5 Guide Comments
Hello please what's the model of the ESD4 and C34 close to the charging port?
Abel Omeokwe - Reply
Where can i get a replacement charging Port?
A K - Reply
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
Tomasz Konwalski - Reply
I've made the replacement, but with a spare type c port and...it's not working. Can someone help?
Delyan - Reply
I use Anker OEM style replacement in my repair shop from eBay listing 254057783007
Perfect fit.
https://www.ebay.com/itm/254057783007
Good luck with the project
G.K. - Reply
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 104
All Time: 4,743
