Anki Cozmo Battery Replacement
  1. Anki Cozmo Battery Replacement, Speaker: step 1, image 1 of 2 Anki Cozmo Battery Replacement, Speaker: step 1, image 2 of 2
    • Remove the two black rubber treads from the wheels using your hands to pull them off.
  2. Anki Cozmo Battery Replacement: step 2, image 1 of 2 Anki Cozmo Battery Replacement: step 2, image 2 of 2
    • Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
    • There are four white hubcaps removed in this step.
  3. Anki Cozmo Battery Replacement: step 3, image 1 of 1
    • Remove the 7.5 mm screw in the middle of each of the four red wheels using a JIS #1 screwdriver.
  4. Anki Cozmo Battery Replacement: step 4, image 1 of 1
    • Remove the red hubcaps from each of the four wheels using your hands and fingers to pull them off.
  5. Anki Cozmo Battery Replacement: step 5, image 1 of 1
    • Remove the 5.5 mm screw on the right side of the front gold bumper using a JIS #1 screwdriver.
  6. Anki Cozmo Battery Replacement: step 6, image 1 of 2 Anki Cozmo Battery Replacement: step 6, image 2 of 2
    • Remove the 5.5 mm screw on the left side of the front gold bumper using a JIS #1 screwdriver.
  7. Anki Cozmo Battery Replacement: step 7, image 1 of 2 Anki Cozmo Battery Replacement: step 7, image 2 of 2
    • Remove the front gold bumper using your hands and fingers to pull it off.
  8. Anki Cozmo Battery Replacement: step 8, image 1 of 2 Anki Cozmo Battery Replacement: step 8, image 2 of 2
    • Remove the two 5.5 mm screws that lay deep on the right side of the gold body using a JIS #0 screwdriver.
    • One screw is towards the front wheel and one screw is towards the back wheel.
  9. Anki Cozmo Battery Replacement: step 9, image 1 of 2 Anki Cozmo Battery Replacement: step 9, image 2 of 2
    • Pry off the two white arms from the right side of the body and the two white arms from the left side of the body using two metal spudgers.
    • Pry off the arms by digging the tips of each spudger in between the arm and the body and pushing up away from the body.
    • The short arm on the right side of the body has a long white spring attached to it that runs through the center of the body.
  10. Anki Cozmo Battery Replacement: step 10, image 1 of 3 Anki Cozmo Battery Replacement: step 10, image 2 of 3 Anki Cozmo Battery Replacement: step 10, image 3 of 3
    • Remove the long white spring that is attached to the right short arm from the center of the body using your hands and fingers to pull it out.
  11. Anki Cozmo Battery Replacement: step 11, image 1 of 2 Anki Cozmo Battery Replacement: step 11, image 2 of 2
    • Pop off the two red square fascia from both sides of the white head using the metal spudger to pop them off.
  12. Anki Cozmo Battery Replacement: step 12, image 1 of 1
    • Remove the two 5.5 mm screws from the right side of the white head using a JIS #0 screwdriver.
  13. Anki Cozmo Battery Replacement: step 13, image 1 of 2 Anki Cozmo Battery Replacement: step 13, image 2 of 2
    • Remove the right side of the white head using your hands and fingers to pull it off.
    • Do not unscrew or remove the two screws or the two white springs from the left side of the white head.
  14. Anki Cozmo Battery Replacement: step 14, image 1 of 1
    • Pop out the black cover screen from the left side of the head using your hands and fingers to pull it out.
  15. Anki Cozmo Battery Replacement: step 15, image 1 of 1
    • Remove the left side of the white head, along with the two short white springs that are attached to it, using your hands and fingers to pull them off.
  16. Anki Cozmo Battery Replacement: step 16, image 1 of 2 Anki Cozmo Battery Replacement: step 16, image 2 of 2
    • Unplug the black LED camera screen and the white and gold speaker from the small white plug in the center of the body using your hands and fingers to pull it off.
    • The camera and the speaker are attached to each other. They are removed in the same step.
  17. Anki Cozmo Battery Replacement, Battery: step 17, image 1 of 1
    • Remove the two 5.5 mm screws from the red trim that was behind the white head using a JIS #1 screwdriver.
  18. Anki Cozmo Battery Replacement: step 18, image 1 of 1
    • Remove the red trim that was behind the white head using your hands and fingers to pull it off.
  19. Anki Cozmo Battery Replacement: step 19, image 1 of 1
    • Pop off the white and gold back trim that is connected to the LED panel using your hands and fingers to pull it off.
    • Do not unplug and remove the white and gold back trim. Leave the white and gold back trim hanging.
  20. Anki Cozmo Battery Replacement: step 20, image 1 of 1
    • Remove the 7.5 mm screw from the gold bar in the center of the body using a JIS #1 screwdriver.
  21. Anki Cozmo Battery Replacement: step 21, image 1 of 3 Anki Cozmo Battery Replacement: step 21, image 2 of 3 Anki Cozmo Battery Replacement: step 21, image 3 of 3
    • Pry apart the two halves of the gold body using your hands and fingers to pull them apart from each other.
  22. Anki Cozmo Battery Replacement: step 22, image 1 of 3 Anki Cozmo Battery Replacement: step 22, image 2 of 3 Anki Cozmo Battery Replacement: step 22, image 3 of 3
    • Unplug and remove the silver battery from the bottom of the charging panel using your hands and fingers to pull it out.
    • Keep track of where the red and black wires get plugged into for reassembly.
13 other people completed this guide.
Marisa Gay
637 Reputation
2 Guides authored
12 Comments
To detach the battery, don’t forget to remove the solder from the two points where the battery connects. (For Cozmo Collectors edition w/ press-able backpack button)
Kaptyn - Reply
The soldering steps are wrong. Don't desolder the speaker, but do desolder the battery.
Scott - Reply
Step 9 should be operated while the arm is at his maximum height.
Eric Hueber - Reply
Yes, excellent tip!
ticom3 -
Step 9 is the hardest from far ! And you'll easily get hurt by your tools. Moreover, reassembling cozmo will certainly deteriorate it. You should operate the big part of the arm (the lower) while the arm is at his maximum height. To do so, disassemble the white part of the fork by prying it down. Then remove the 2 screws of the upper arms, and remove these arms. Eventually, the big arm is easy to remove (or to reassemble).
Eric Hueber - Reply
Past 24 Hours: 12
Past 7 Days: 131
Past 30 Days: 566
All Time: 15,558
