Answering Machine Speaker Replacement
  1. Answering Machine Speaker Replacement, Base: step 1, image 1 of 1
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Answering Machine Speaker Replacement: step 2, image 1 of 2 Answering Machine Speaker Replacement: step 2, image 2 of 2
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Answering Machine Speaker Replacement, Answering Machine Speaker: step 3, image 1 of 2 Answering Machine Speaker Replacement, Answering Machine Speaker: step 3, image 2 of 2
    • Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
    • Use a screwdriver to remove the two 7mm Phillips #0 screws.
  4. Answering Machine Speaker Replacement: step 4, image 1 of 1
    • Finish speaker removal by cutting both the black and red wires.
  5. Answering Machine Speaker Replacement: step 5, image 1 of 1
Troy Chester
84 Reputation
1 Guide authored
IUPUI, Team 3-3, Harley Fall 2016 Member of IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 13
All Time: 853
