Apex TM772 Rear Camera Replacement
  1. Apex TM772 Rear Camera Replacement, Rear Camera: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • The rear facing camera is located at the top right just below the front facing camera as looking inside the device.
    • With tweezers or your fingers remove the tape covering the camera’s pin connector.
  2. Apex TM772 Rear Camera Replacement: step 2, image 1 of 1
    • With tweezers, flip the black latch to open the pin connector and remove the cable.
    • The camera is adhered to the device with double sided foam tape. Carefully remove the camera from the tape with a metal spudger. If the tape is damaged, you’ll need to replace it.
    • Replace the camera with the new one and assemble the device in reverse of these instructions.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 152
