Apple EarPods Disassembly
  1. Apple EarPods Disassembly, Tools You Need: step 1, image 1 of 2 Apple EarPods Disassembly, Tools You Need: step 1, image 2 of 2
    • X-ACTO Knife
    • Tweezer
    • Triangle Paddle
    • Alcohol
    • Cotton Swabs
  2. Apple EarPods Disassembly, Opening Earpod: step 2, image 1 of 2 Apple EarPods Disassembly, Opening Earpod: step 2, image 2 of 2
    • Using a triangle paddle, apply sufficient pressure to get in-between the opening section
  3. Apple EarPods Disassembly, Cleaning Inside and Out: step 3, image 1 of 1
    • Soak one side of a cotton swab with alcohol
    • Clean inner and outer pod using swab soaked in alcohol
  4. Apple EarPods Disassembly, Cleaning the Speaker Cone: step 4, image 1 of 1
    • Carefully clean the speaker cone using cotton swab
    • Once clean, reattach the earbud
  5. Apple EarPods Disassembly, Removing the Grill: step 5, image 1 of 2 Apple EarPods Disassembly, Removing the Grill: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully remove grill out of both earbuds using tweezers
    • Take precautions not to bend grill excessively
  6. Apple EarPods Disassembly, Grill Polishing: step 6, image 1 of 1
    • Clean grill with cotton swab soaked in alcohol
    • Remove any build up of wax or sweat
  7. Apple EarPods Disassembly, Placing Grill Back: step 7, image 1 of 2 Apple EarPods Disassembly, Placing Grill Back: step 7, image 2 of 2
    • Once the grill is clean, place the grill back inside of the apple earbuds
To reassemble your device, follow Step 7, Step 4 and Step 2 instructions in reverse order.
8 other people completed this guide.
Eduardo Gonzalez
395 Reputation
1 Guide authored
1 Guide Comment
When I re assemble they won’t stay closed. Do I glue them back together?
Patrick Appleby - Reply
Past 24 Hours: 6
Past 7 Days: 66
Past 30 Days: 301
All Time: 50,188
