Apple IIc Keyboard Replacement
  1. Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: step 1, image 1 of 2 Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: step 1, image 2 of 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Keyboard Replacement: step 2, image 1 of 2 Apple IIc Keyboard Replacement: step 2, image 2 of 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Keyboard Replacement: step 3, image 1 of 2 Apple IIc Keyboard Replacement: step 3, image 2 of 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Keyboard Replacement: step 4, image 1 of 2 Apple IIc Keyboard Replacement: step 4, image 2 of 2
    • Lift the handle straight up to remove.
  5. Apple IIc Keyboard Replacement, Keyboard: step 5, image 1 of 2 Apple IIc Keyboard Replacement, Keyboard: step 5, image 2 of 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
4 other people completed this guide.
Alexandria Weinberg
601 Reputation
3 Guides authored
Cal Poly, Team 21-23, Maness Fall 2011 Member of Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 3,698
