Apple Magic Keyboard Keys Repair
    • Remove the batteries.
    • Remove the plastic cover on the bottom. (On older models, this cover is not centered.)
    • Remove the small screw.
    • Use a flat blunt tool to loosen the ribbon cable clamp. To do this, pull the front part away from the rear part.
    • Pull out the ribbon cable.
    • Put the batteries back in (without screwing the cover on).
    • Push in the batteries to release the circuit board assembly.
    • Carefully pull out the circuit board assembly. Pay attention to the ribbon cable.
    • Soak the keyboard in alcohol (methylated spirits). It should be completely covered. Use an airtight container.
    • Keep moving the container to get the liquid everywhere.
    • Wait 24 hours
    • Take the keyboard out of the liquid and shake it out well.
    • CAUTION!! This step is not absolutely necessary!! Opening the keyboard further is only necessary if you want to gain access to the circuit paths.
    • The plastic cover on the back can now be easily detached. To do this, use a flat blunt tool to go into the gap and pry off the plastic cover. The alcohol has softened the glue.
    • Let the keyboard dry well. To speed up the process, you can put it into the sun.
    • Put the parts back together in reverse order. When installing the circuit board unit, make sure that you pull the ribbon cable to the side.
Finish Line
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Sebastian Reindl
268 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 42
Past 30 Days: 186
All Time: 4,820
