Apple PowerBook 520 Memory (RAM) Replacement
  1. Apple PowerBook 520 Memory (RAM) Replacement, Case: step 1, image 1 of 2 Apple PowerBook 520 Memory (RAM) Replacement, Case: step 1, image 2 of 2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple PowerBook 520 Memory (RAM) Replacement: step 2, image 1 of 1
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Apple PowerBook 520 Memory (RAM) Replacement: step 3, image 1 of 1
    • Remove top left and top right screws.
  4. Apple PowerBook 520 Memory (RAM) Replacement: step 4, image 1 of 1
    • Remove middle left and middle right screws.
  5. Apple PowerBook 520 Memory (RAM) Replacement: step 5, image 1 of 1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Apple PowerBook 520 Memory (RAM) Replacement: step 6, image 1 of 1
    • Lift keyboard from bottom and take out of shell.
  7. Apple PowerBook 520 Memory (RAM) Replacement: step 7, image 1 of 3 Apple PowerBook 520 Memory (RAM) Replacement: step 7, image 2 of 3 Apple PowerBook 520 Memory (RAM) Replacement: step 7, image 3 of 3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
  8. Apple PowerBook 520 Memory (RAM) Replacement, Memory (RAM): step 8, image 1 of 1
    • Open the panel on back of the device. Remove 2 T8 torque screws.
  9. Apple PowerBook 520 Memory (RAM) Replacement: step 9, image 1 of 1
    • Remove the plastic panel underneath the LCD Screen.
  10. Apple PowerBook 520 Memory (RAM) Replacement: step 10, image 1 of 1
    • Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
  11. Apple PowerBook 520 Memory (RAM) Replacement: step 11, image 1 of 1
    • Remove the logic board protection plate.
  12. Apple PowerBook 520 Memory (RAM) Replacement: step 12, image 1 of 1
    • Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
  13. Apple PowerBook 520 Memory (RAM) Replacement: step 13, image 1 of 1
    • Once the old Memory board is removed, replace it with the new Memory board.
2 other people completed this guide.
Tyler
148 Reputation
2 Guides authored
Cal Poly, Team 20-66, Walters Spring 2011 Member of Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Members
3 Guides authored
1 Guide Comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 3,760
