Apple Powerbook 520/540 General Disassembly
  1. Apple Powerbook 520/540 General Disassembly, Case: step 1, image 1 of 2 Apple Powerbook 520/540 General Disassembly, Case: step 1, image 2 of 2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: step 2, image 1 of 1
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Apple Powerbook 520/540 General Disassembly: step 3, image 1 of 1
    • Remove top left and top right screws.
  4. Apple Powerbook 520/540 General Disassembly: step 4, image 1 of 1
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: step 5, image 1 of 1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Apple Powerbook 520/540 General Disassembly: step 6, image 1 of 1
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: step 7, image 1 of 3 Apple Powerbook 520/540 General Disassembly: step 7, image 2 of 3 Apple Powerbook 520/540 General Disassembly: step 7, image 3 of 3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
11 other people completed this guide.
Mark McNeff
515 Reputation
2 Guides authored
2 Guide Comments
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Reply
Thanks been trying to fix this for a long time
Luke - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 37
All Time: 7,441
