Apple Powerbook 520 Hard Drive Replacement
  1. Apple Powerbook 520 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • After completing the initial disassembly, you may proceed to hard drive replacement.
  2. Apple Powerbook 520 Hard Drive Replacement: step 2, image 1 of 2 Apple Powerbook 520 Hard Drive Replacement: step 2, image 2 of 2
    • First, you will need to remove the five T8 torx screws that mount the hard drive to the internal frame.
    • Next, you will remove the mounting frame and the plastic shield.
  3. Apple Powerbook 520 Hard Drive Replacement: step 3, image 1 of 1
    • You can use a spudger (tool shown in photo) to remove the ribbon cable from the hard drive.
  4. Apple Powerbook 520 Hard Drive Replacement: step 4, image 1 of 1
    • Carefully, pry the ribbon away from the pins.
  5. Apple Powerbook 520 Hard Drive Replacement: step 5, image 1 of 1
    • Attach the ribbon cable to the new hard drive and follow steps 1-3, in reverse, to complete the installation.
4 other people completed this guide.
Tyler
148 Reputation
2 Guides authored
Cal Poly, Team 20-66, Walters Spring 2011 Member of Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 5,427
