Slide the release button toward you and pull out the main battery from the right battery bay of the computer.
Repeat the procedure for the second battery, if installed, in the left battery bay of the computer.
If a PCMCIA card is installed, eject the card first, then remove the PCMCIA card cage from the left battery bay.
Using a T8 torx driver, remove the middle two bottom housing screws
Using a small flat-blade screwdriver, lift the front of the keyboard and pull it forward slightly.
Rotate the keyboard so that it is perpendicular to the top cover.
Release the locking tabs on the two keyboard cable connectors and disconnect the cables from the motherboard
Lift off the keyboard.
Using a T8 torx driver, remove the hard drive mounting screw.
Using a small flat-blade screwdriver, pry up the front of the hard drive and slide it forward.
Lift the drive partway out of the unit and disconnect the hard drive cable.
Remove the hard drive.
If you are replacing the hard drive, remove the four screws and remove the hard drive bracket and insulator.
Using a T-8 torx driver, remove the two floppy drive screws.
Using a small flat-blade screwdriver, pry up the cable end of the floppy drive and slide the drive to the left.
Slide the drive forward slightly and lift it partway out of the unit.
Disconnect the floppy drive cable from the motherboard and remove the drive.
If you are replacing the floppy drive or floppy drive cable, release the locking tabs and disconnect the cable from the drive.
Open the unit and rotate the display assembly as far back as it will go.
Using a flat-blade screwdriver and your fingers, press in on both sides of the wide end of the right clutch cover and release the two front latches.
Rotate the clutch cover up, release the third latch, and remove the cover.
Repeat for the other clutch cover.
Using a small flat-blade screwdriver, pry up the display access cover at the three slots in the front of the cover.
Remove the display access cover.
Disconnect the interconnect to logic board cable.
Using a T-8 torx driver, remove the two display mounting screws.
Slide the display assembly to the left so that the right clutch clears the loop of the interconnect to logic board cable.
Remove the display assembly.
Using a T-8 torx driver, remove the two rear panel screws.
Pull the center base cover forward slightly and slide it to the right to release the two screw carriers.
Remove the center base cover.
Rotate the feet to the up position.
Using a T-8 torx driver, remove the screw located under each foot.
Remove the four screws at the front edge of the bottom case
Remove the remaining screw on the inside top edge of the case.
Carefully lift and rotate the top case toward you and disconnect the track pad cable from the motherboard.
Remove the interconnect to logic board cable from the opening for the right clutch.
Remove the top case.
With a T8 Torx driver, remove the three mounting screws on the EMI shield.
Using a small flat-blade screwdriver, pry up and remove the daughterboard EMI shield.
Remove the plastic retainer bar.
You will need an IC extractor. I do not recommend using a flat head screwdriver
Place the legs of the IC extractor in the notches at the end of the daughterboard and pull up.
Remove the two screws from the plastic retainer bar.
Gently but firmly slide the plastic retainer bar away from the RAM card to release it.
Insert the IC puller along the two notches on either side of the RAM card.
Gripping the IC puller firmly, pull straight up to remove the RAM card.
To remove the modem card, place the legs of the IC extractor in the notches at the end of the board and pull up.
Disconnect the interconnect to logic board cable from the motherboard and remove the cable.
Using a T-8 torx driver, remove the three right side panel mounting screw.
Lift the panel slightly, slide it back, and remove it from the CPU stiffener.
Using a T-8 torx driver, remove the three left side-panel mounting screws.
Slide the panel to the left and remove it from the CPU stiffener.
Unlatch the left side panel from the back panel.
Lift the CPU stiffener straight off the unit.
Remove the motherboard mounting screw and standoff.
Carefully pry the motherboard from the positioning peg located below the standoff.
Slide the board forward and lift it out.
Turn over the motherboard.
Disconnect the hard drive cable from the motherboard.
Carefully disconnect the microphone cable from the interconnect board.
Using a small flat-blade screwdriver, pry up and remove the microphone assembly.
Using a small flat-blade screwdriver, pry up and remove the backup battery cover.
Carefully disconnect the backup battery cable.
Remove the cable from the cable guides.
Pry up and remove the backup battery and cable.
Using a T-8 torx driver, remove the front two mounting screws.
Disconnect the trackpad cable assembly and remove it from the unit.
Using a T-8 torx driver, remove the remaining two mounting screws
Pry up and remove the trackpad actuator assembly.
With your fingers, push up from underneath the trackpad logic board and remove it from the top case
Disconnect the speaker cable from the interconnect board.
Remove the bottom two bezel mounting screws.
Pry off the two rubber bumpers and remove the top two bezel mounting screws.
Pull the display bezel forward and lift it off the rear housing.
Remove the four mounting screws.
Disconnect the backlight cable from the inverter board.
Lift the display from the rear housing.
Remove the two mounting screws
Disconnect the interconnect to inverter cable and the backlight cable.
Remove the inverter board.
Disconnect the interconnect to display cable and the interconnect to inverter cable.
Remove the two mounting screws.
Remove the interconnect board.
Disconnect the interconnect to inverter cable from the interconnect and inverter boards.
Remove the cable from the back housing.
Disconnect the interconnect to display cable from the back of the display.
Remove the cable.
Remove the mounting screw for the right clutch and remove the clutch.
Repeat for the left clutch
