Introduction
Replace your Apple TV's 1st Generation logic board.
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
Pry the AirPort antenna cables straight up from their sockets on the logic board.
Disconnect the power cable straight up from its socket on the logic board.
7 other people completed this guide.
