Apple TV 4K Power Supply Replacement
  1. Apple TV 4K Power Supply Replacement, Logic Board: step 1, image 1 of 1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Power Supply Replacement: step 2, image 1 of 2 Apple TV 4K Power Supply Replacement: step 2, image 2 of 2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Power Supply Replacement: step 3, image 1 of 2 Apple TV 4K Power Supply Replacement: step 3, image 2 of 2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Power Supply Replacement: step 4, image 1 of 1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Power Supply Replacement: step 5, image 1 of 3 Apple TV 4K Power Supply Replacement: step 5, image 2 of 3 Apple TV 4K Power Supply Replacement: step 5, image 3 of 3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
  6. Apple TV 4K Power Supply Replacement, Power Supply: step 6, image 1 of 3 Apple TV 4K Power Supply Replacement, Power Supply: step 6, image 2 of 3 Apple TV 4K Power Supply Replacement, Power Supply: step 6, image 3 of 3
    • Use a T7 Torx to remove the screws:
    • Five 5mm screws
    • Carefully flip the device upside down to remove the logic board/power supply mount.
  7. Apple TV 4K Power Supply Replacement: step 7, image 1 of 2 Apple TV 4K Power Supply Replacement: step 7, image 2 of 2
    • Undo the latch connecting the power connector to the power supply.
    • Feed the wire though the logic board/power supply mount.
  8. Apple TV 4K Power Supply Replacement: step 8, image 1 of 3 Apple TV 4K Power Supply Replacement: step 8, image 2 of 3 Apple TV 4K Power Supply Replacement: step 8, image 3 of 3
    • Using a T-7 Torx unscrew the two silver screws.
    • Two 4mm silver screws
    • The power connector piece on the other side will now be free and fall out.
  9. Apple TV 4K Power Supply Replacement: step 9, image 1 of 3 Apple TV 4K Power Supply Replacement: step 9, image 2 of 3 Apple TV 4K Power Supply Replacement: step 9, image 3 of 3
    • Use a screwdriver with a T-7 Torx bit to remove the following screws:
    • Five black 3mm screws
    • lift the power supply out of it's mount.
  10. Apple TV 4K Power Supply Replacement: step 10, image 1 of 1
    • Use a T6 Torx to remove the two screws holding the power supply connector in place. Pull the power connector away from the case.
    • Two 3mm screws
9 other people completed this guide.
Brian Gehring
451 Reputation
2 Guides authored
UW Stout, Team S6-G3, Ogden Fall 2018 Member of UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Members
15 Guides authored
8 Comments
Does anyone know where I can buy a replacement board?
mike - Reply
I have the same question, where can one find the replacement power supply board for the Apple TV 4K?
cclakeman - Reply
Please, explain the 12V power supply topic: does that means it can be installed in a car or a boat out of the box?
matejmunih - Reply
I had an Apple dealer (independent) tell me that they couldn’t order the power supply. They could only send the unit to Apple for exchange with a refurbished unit (at 2/3rds the cost of a new one). Boooo!
bat21 - Reply
Ach Leute! Wieder eine Sackgasse! Es ist so frustrierend – was nutzt eine Anleitung, wenn man die Power Supply nirgends woher bekommt?
Steven - Reply
Past 24 Hours: 11
Past 7 Days: 47
Past 30 Days: 231
All Time: 12,679
