Apple TV 4K Remote Logic Board Replacement
  1. Apple TV 4K Remote Logic Board Replacement, Remote Logic Board: step 1, image 1 of 1
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Logic Board Replacement: step 2, image 1 of 2 Apple TV 4K Remote Logic Board Replacement: step 2, image 2 of 2
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Logic Board Replacement: step 3, image 1 of 1
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Logic Board Replacement: step 4, image 1 of 2 Apple TV 4K Remote Logic Board Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Unlatch the connector that binds the touch screen and logic board.
    • Afterwards, use tweezers to detach the connector that binds the touch screen to the logic board.
  5. Apple TV 4K Remote Logic Board Replacement: step 5, image 1 of 1
    • Lift the face from the body of the remote.
  6. Apple TV 4K Remote Logic Board Replacement: step 6, image 1 of 2 Apple TV 4K Remote Logic Board Replacement: step 6, image 2 of 2
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  7. Apple TV 4K Remote Logic Board Replacement: step 7, image 1 of 1
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  8. Apple TV 4K Remote Logic Board Replacement: step 8, image 1 of 1
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
2 other people completed this guide.
Keenan Barber
1,159 Reputation
3 Guides authored
UW Stout, Team S6-G3, Ogden Fall 2018 Member of UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Members
15 Guides authored
One Comment
Have you ever successfully reconnected the ribbon cable after disassembly? It seems nearly impossible to do by hand…
B R - Reply
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 114
All Time: 4,600
