Apple Time Capsule Model A1254 Back Plate Replacement
  1. Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: step 1, image 1 of 3 Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: step 1, image 2 of 3 Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: step 1, image 3 of 3
    • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
    • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
    • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
    • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
  2. Apple Time Capsule Model A1254 Back Plate Replacement: step 2, image 1 of 2 Apple Time Capsule Model A1254 Back Plate Replacement: step 2, image 2 of 2
    • Remove the ten 3mm screws with a Phillips #00 screwdriver.
    • The screws with adhesive covering do not need to be removed.
  3. Apple Time Capsule Model A1254 Back Plate Replacement: step 3, image 1 of 2 Apple Time Capsule Model A1254 Back Plate Replacement: step 3, image 2 of 2
    • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
    • Pull the base of the wire close to the logic board and the connector will pop off.
9 other people completed this guide.
Keaton Frahmann
822 Reputation
2 Guides authored
Cal Poly, Team 4-2, Livingston Fall 2016 Member of Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
4 Members
17 Guides authored
2 Comments
I had to open to destroy the hard drive for security reasons. The rubber bottom was so old it just tore to bits. I used a Dremel Multi-Max with a flat scraper blade to remove it in the end.
steve - Reply
must I put back on the rubber bottom or can I leave it off for maximum airflow?
Strider - Reply
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 49
All Time: 6,272
