Introduction
Use this guide to open your Apple Watch Series 8 for repairs.
Note: The opening procedure for the 41 mm and the 45 mm Apple Watch series 8 is the same. You can use this guide for both models.
This guide shows the procedure on the cellular/LTE version of the watch, but the GPS-only version is similar.
You’ll need replacement adhesive for the screen when reassembling the device.
Prepare an iOpener and apply it to the screen for three minutes to loosen the adhesive underneath.
Insert the iFlex into the thin gap between the display and frame at the edge adjacent to the digital crown.
Tilt the iFlex down to pry the display open slightly and create a gap between the screen and the watch body.
Insert the tip of an opening pick into the gap you just created.
Slide the opening pick along the short edge of the watch to slice the adhesive.
Lift the display and carefully pull it towards the watch crown.
Swing the display open to an upright position.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
One Comment
It would be helpful if at the beginning of the article, at the very top, there was a notice letting us know we should replace the battery when we replace the screen, as long with a link to that part. Because I ordered all the parts (battery not listed), tore the watch down, then got to the part about replacing the battery. So I've had the watch tore down, opened, waiting for someone to get the battery in stock. I would have waited to tear the watch down if I knew. Otherwise great article.
