Apple Watch SE Watch Band Replacement
  1. Apple Watch SE Watch Band Replacement, Watch Band: step 1, image 1 of 3 Apple Watch SE Watch Band Replacement, Watch Band: step 1, image 2 of 3 Apple Watch SE Watch Band Replacement, Watch Band: step 1, image 3 of 3
    • Turn off your device by holding down the side button until the slider appears.
    • Tap the Power button at the top right hand corner.
    • Slide the Power Off slider to the right.
  2. Apple Watch SE Watch Band Replacement: step 2, image 1 of 1
    • Lay your Apple Watch face down on a soft, clean surface to avoid scratching the screen.
  3. Apple Watch SE Watch Band Replacement: step 3, image 1 of 3 Apple Watch SE Watch Band Replacement: step 3, image 2 of 3 Apple Watch SE Watch Band Replacement: step 3, image 3 of 3
    • Hold down one of the release buttons on the back of the device, and slide out its corresponding band at the same time.
    • This may take some effort. If the band does not slide out, press down the release button again and make sure to hold it down.
  4. Apple Watch SE Watch Band Replacement: step 4, image 1 of 2 Apple Watch SE Watch Band Replacement: step 4, image 2 of 2
    • Repeat Step 3 with the other side of the band.
  5. Apple Watch SE Watch Band Replacement: step 5, image 1 of 2 Apple Watch SE Watch Band Replacement: step 5, image 2 of 2
    • Gently wipe any residue off of the back of the watch using a gentle towel, cotton swab, or cotton ball.
    • Do not use any abrasive chemicals.
  6. Apple Watch SE Watch Band Replacement: step 6, image 1 of 2 Apple Watch SE Watch Band Replacement: step 6, image 2 of 2
    • Take the new watch band and make sure the side of the band with metal connectors is facing the watch, and the correct orientation is followed.
  7. Apple Watch SE Watch Band Replacement: step 7, image 1 of 2 Apple Watch SE Watch Band Replacement: step 7, image 2 of 2
    • Gently slide the new band into the slot.
    • It will click into place when it is properly secured.
    • Repeat on the other side.
Finish Line
Destiny Holtzman
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 29
All Time: 418
