Apple Watch Ultra Battery Replacement
  1. Apple Watch Ultra Battery Replacement, Power down your watch: step 1, image 1 of 2 Apple Watch Ultra Battery Replacement, Power down your watch: step 1, image 2 of 2
    • Drain your watch battery below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Take your watch off the charger and power it down.
    • If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
  2. Apple Watch Ultra Battery Replacement, Safety details: step 2, image 1 of 3 Apple Watch Ultra Battery Replacement, Safety details: step 2, image 2 of 3 Apple Watch Ultra Battery Replacement, Safety details: step 2, image 3 of 3
    • Because the gap between the screen assembly and frame is so small, a thin metal tool is needed to pry the screen up. Read the following warnings before you start disassembly:
    • Protect your fingers by keeping them completely clear of the front end of your tool. You can protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the iFlex to slip and cut you, or damage the watch.
    • Wear eye protection. The glass may break, sending pieces flying.
    • Attach or remove the watch bands as needed to provide more control as you make repairs.
  3. Apple Watch Ultra Battery Replacement, Soften the screen adhesive: step 3, image 1 of 1
    • Heat an iOpener and apply it to the screen for two minutes to loosen the adhesive underneath.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  4. Apple Watch Ultra Battery Replacement, Insert the iFlex: step 4, image 1 of 3 Apple Watch Ultra Battery Replacement, Insert the iFlex: step 4, image 2 of 3 Apple Watch Ultra Battery Replacement, Insert the iFlex: step 4, image 3 of 3
    • Place the tip of an iFlex along the edge opposite the Digital Crown and position it in the seam between the screen and the frame.
    • Press the iFlex firmly straight down into the gap.
    • The gap between the screen and the frame is very small, and it makes inserting the iFlex difficult. Don't force the iFlex in, or you risk damaging the screen. If you're having trouble, apply more heat and try again.
  5. Apple Watch Ultra Battery Replacement, Pry up the screen: step 5, image 1 of 2 Apple Watch Ultra Battery Replacement, Pry up the screen: step 5, image 2 of 2
    • Use the iFlex to pry up the screen.
    • The adhesive requires time and constant force to loosen—it probably won't loosen from the initial pry. Reheat the screen and keep applying constant force until the adhesive loosens.
  6. Apple Watch Ultra Battery Replacement, Insert an opening pick: step 6, image 1 of 3 Apple Watch Ultra Battery Replacement, Insert an opening pick: step 6, image 2 of 3 Apple Watch Ultra Battery Replacement, Insert an opening pick: step 6, image 3 of 3
    • Insert an opening pick in the gap you created between the screen and the frame.
    • Remove the iFlex.
  7. Apple Watch Ultra Battery Replacement, Slice the adhesive: step 7, image 1 of 3 Apple Watch Ultra Battery Replacement, Slice the adhesive: step 7, image 2 of 3 Apple Watch Ultra Battery Replacement, Slice the adhesive: step 7, image 3 of 3
    • Insert the tip of the opening pick less than 2 mm to prevent damaging the antenna pin.
    • Slide the opening pick around the top left corner and along the top edge of the watch to slice the screen adhesive.
  8. Apple Watch Ultra Battery Replacement: step 8, image 1 of 2 Apple Watch Ultra Battery Replacement: step 8, image 2 of 2
    • Slide the opening pick around the top right corner and stop just before the Digital Crown.
  9. Apple Watch Ultra Battery Replacement: step 9, image 1 of 2 Apple Watch Ultra Battery Replacement: step 9, image 2 of 2
    • Insert an opening pick into the seam at the top left corner of the watch.
    • Slide the pick along the Action button edge to slice the adhesive.
  10. Apple Watch Ultra Battery Replacement: step 10, image 1 of 2 Apple Watch Ultra Battery Replacement: step 10, image 2 of 2
    • Slide the opening pick around the bottom left corner and along the bottom edge of the watch to slice the screen adhesive.
  11. Apple Watch Ultra Battery Replacement: step 11, image 1 of 2 Apple Watch Ultra Battery Replacement: step 11, image 2 of 2
    • Slide the opening pick around the bottom right corner and stop before you reach the side button.
  12. Apple Watch Ultra Battery Replacement, Lift the screen: step 12, image 1 of 2 Apple Watch Ultra Battery Replacement, Lift the screen: step 12, image 2 of 2
    • Insert the opening pick between the screen and frame at the opposite edge of the Digital Crown.
    • Pry up the screen until you can get a good grip with your fingers.
    • Don't try to remove the screen all the way yet. It's still connected to the watch body.
  13. Apple Watch Ultra Battery Replacement, Swing open the screen: step 13, image 1 of 3 Apple Watch Ultra Battery Replacement, Swing open the screen: step 13, image 2 of 3 Apple Watch Ultra Battery Replacement, Swing open the screen: step 13, image 3 of 3
    • Be careful not to strain the screen cable when you swing open the screen.
    • Lift the screen up and carefully pull it towards the Digital Crown.
    • Swing the screen open to an upward position.
  14. Apple Watch Ultra Battery Replacement, Remove the two connector bracket screws: step 14, image 1 of 1
    • Use a Y000 driver to remove the two 2.3 mm‑long screws securing the metal connector bracket at the bottom edge of the watch.
  15. Apple Watch Ultra Battery Replacement, Remove the bottom connector bracket: step 15, image 1 of 2 Apple Watch Ultra Battery Replacement, Remove the bottom connector bracket: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the bottom connector bracket.
  16. Apple Watch Ultra Battery Replacement, Disconnect the battery: step 16, image 1 of 2 Apple Watch Ultra Battery Replacement, Disconnect the battery: step 16, image 2 of 2
    • Use the point of a spudger to pry up the battery connector towards the battery.
    • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power your watch back down completely before you continue working.
  17. Apple Watch Ultra Battery Replacement, Remove the upper battery screws: step 17, image 1 of 2 Apple Watch Ultra Battery Replacement, Remove the upper battery screws: step 17, image 2 of 2
    • Use a Y000 driver to remove the 2.9 mm‑long screw securing the battery.
    • Use a Y000 driver to unscrew the 2.1 mm‑long screw that's sandwiched between the metal bracket.
  18. Apple Watch Ultra Battery Replacement, Remove the metal bracket including the screw: step 18, image 1 of 2 Apple Watch Ultra Battery Replacement, Remove the metal bracket including the screw: step 18, image 2 of 2
    • Use a pair of tweezers to remove the bracket with the screw sandwiched between it.
    • Although the screw sits nicely in the bracket, it’s not captive and can fall out.
  19. Apple Watch Ultra Battery Replacement, Remove the battery: step 19, image 1 of 3 Apple Watch Ultra Battery Replacement, Remove the battery: step 19, image 2 of 3 Apple Watch Ultra Battery Replacement, Remove the battery: step 19, image 3 of 3
    • Use an opening pick to lift up the battery.
    • Remove the battery from the case.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your Apple Watch Ultra, follow these instructions in reverse order. Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
For optimal performance, calibrate your newly installed battery after completing this guide.
8 other people completed this guide.
Dominik Schnabelrauch
251,920 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,252 Guides authored
6 Guide Comments
Is it possible to reboot the device after changing the battery so that my i cloud account is locked?
Fazza - Reply Share
Man... i knew seeing screws on the back side of it were a false sense of security...
MICHAEL GARCIA - Reply Share
Completed the repair yesterday. Needed to get the display seal elsewhere since iFixit doesn't seem to have it on this site. Wished they had a complete set of thin opening tool, Display seal, Battery and screwdriver-bit.
First tried the repair with iOpener but it wouldnt get the glue loose enough so used a heatgun several times to not overheat the watch. Took an extensive amount of prying until the display came loose.
That little bracket broke when prying it open to access the screw (bit was to big) but the watch works just fine even with broken bracket.
Other than that removal of old glue took a tremendous amout of Alcohol (for the watch, not me) but reinstalling the new seal was relatively easy. Display is glued in and the watch works flawlessly. The iFixit Battery was delivered completely empty - I'd have expeted at least 25% charge to at least be able to power on the device for checking. After half an hour of charing it worked fine.
Please update the guide with display-re-sealing topic.
macmaniacs - Reply Share
Says how to get it apart and replace the battery but not how to get it back together again. Requires at least one seal as it describes “cutting adhesive”. This is a major problem. This guide is incomplete.
Matthew Marks - Reply Share
Battery is £75, plus the risk of making a pig's ear of the actual repair. Price from Apple for the whole job is £100.00. I've done a lot of iFixit repairs on Macs and phones but in this case the DIY repair just doesn't seem sensible....
Isidore - Reply Share
Past 24 Hours: 47
Past 7 Days: 387
Past 30 Days: 1,564
All Time: 42,503
