Apple XServe Raid Battery Replacement
  1. Apple XServe Raid Battery Replacement, Raid Battery: step 1, image 1 of 2 Apple XServe Raid Battery Replacement, Raid Battery: step 1, image 2 of 2
    • Remove the drive module(s) from the front of the Xserve.
    • Depending on configuration, there may be up to three modules.
  2. Apple XServe Raid Battery Replacement: step 2, image 1 of 1
    • Remove the power supplies from the system by pulling on the built-in removal bar.
    • Depending on configuration, there may only be one power supply unit.
  3. Apple XServe Raid Battery Replacement: step 3, image 1 of 1
    • Remove the top cover of the system by loosening the two thumb screws located on the back panel.
    • Discharge any static electricity by touching a grounded surface. Failure to do so may cause damage to the internal components.
  4. Apple XServe Raid Battery Replacement: step 4, image 1 of 3 Apple XServe Raid Battery Replacement: step 4, image 2 of 3 Apple XServe Raid Battery Replacement: step 4, image 3 of 3
    • Remove the fan module by loosening the two Phillips #0 screws located on each side of the module.
  5. Apple XServe Raid Battery Replacement: step 5, image 1 of 1
    • Disconnect the raid battery connector using a plastic spudger.
  6. Apple XServe Raid Battery Replacement: step 6, image 1 of 2 Apple XServe Raid Battery Replacement: step 6, image 2 of 2
    • Remove the SAS backplane power cable by pulling the cable out of the board.
    • Remove the data cable from the board using a spudger to lift the connector out of the socket.
    • Loosen the Phillips #0 screw holding the backplane in the system.
    • To remove the backplane from the chassis, slide the board down, tilt it to a 45 degree angle, and pull the board out.
  7. Apple XServe Raid Battery Replacement: step 7, image 1 of 1
    • Loosen the single Phillips #0 screw on the power backplane.
    • Slide the backplane out of the connector on the main board, and lift it straight out.
  8. Apple XServe Raid Battery Replacement: step 8, image 1 of 1
    • Lift the raid card battery out of the chassis.
2 other people completed this guide.
Cody West
234 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 17
All Time: 780
