Introduction
You will be separating the camera module from the rest of the device. This include removing 3 pin tabs/ribbons from the circuit board. You will have to do this carefully as any damage done to the pins will be hard to repair. The rest is just unscrewing screws.
Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
4 other people completed this guide.
