Archos 101 G9 Flash Memory Replacement
Deneille Davids
Deneille Davids and 3 other contributors
Last updated on December 22, 2021
1 hour
Very difficult
Introduction
Go to step 1
Use this guide to replace the flash memory in your Archos 101 G9 tablet.
The Archos 101 G9 tablet flash memory, also known as flash storage, is a storage unit for the tablet. Issues with a full memory can lead to a non-functioning device. Before replacing the flash memory, try to perform a factory reset on your device to see if that can possibly help; follow this guide for instructions. If that does not work and your flash memory is still the main problem, then use this guide to replace your flash memory. Before starting, make sure to completely power off your tablet and disconnect the tablet from any external power source.
Tools
Show more…
  1. Archos 101 G9 Flash Memory Replacement, Display Assembly: step 1, image 1 of 1
    • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
    • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
    • When you reach the corner, carefully pry the two halves of the device apart.
    • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
    • Repeat for the remaining three sides and corners.
  2. Archos 101 G9 Flash Memory Replacement: step 2, image 1 of 2 Archos 101 G9 Flash Memory Replacement: step 2, image 2 of 2
    • Separate the halves of the device.
    • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
  3. Archos 101 G9 Flash Memory Replacement: step 3, image 1 of 2 Archos 101 G9 Flash Memory Replacement: step 3, image 2 of 2
    • Gently remove both ribbon cables from their sockets on the motherboard.
  4. Archos 101 G9 Flash Memory Replacement: step 4, image 1 of 1
    • Remove the white and black coaxial cables with gold tips from the motherboard.
  5. Archos 101 G9 Flash Memory Replacement: step 5, image 1 of 1
    • Remove the display assembly from the back panel.
  6. Archos 101 G9 Flash Memory Replacement, Motherboard: step 6, image 1 of 1
    • Remove the 2 mm screw that holds the motherboard in place using a Phillips #0 screwdriver.
  7. Archos 101 G9 Flash Memory Replacement: step 7, image 1 of 1
    • Carefully remove the ribbon cable from its socket on the motherboard.
  8. Archos 101 G9 Flash Memory Replacement: step 8, image 1 of 1
    • Remove the tape covering all of the solder connections on the motherboard.
  9. Archos 101 G9 Flash Memory Replacement: step 9, image 1 of 1
    • Desolder all six of the connections that were underneath the tape.
  10. Archos 101 G9 Flash Memory Replacement: step 10, image 1 of 1
    • Remove the motherboard from the tablet.
  11. Archos 101 G9 Flash Memory Replacement, Flash Memory: step 11, image 1 of 1
    • Flip the motherboard around to the backside and pry off the silver covering using a nylon spudger.
  12. Archos 101 G9 Flash Memory Replacement: step 12, image 1 of 1
    • Remove the largest black rectangle using the Hakko microsoldering kit.
Deneille Davids
181 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 8
All Time: 331
