Armitron Base Metal Bezel Stainless Steel Back Battery Replacement
  1. Armitron Base Metal Bezel Stainless Steel Back Battery Replacement, Prep: step 1, image 1 of 1
    • Get the watch ready by placing it on its face.
  2. Armitron Base Metal Bezel Stainless Steel Back Battery Replacement: step 2, image 1 of 1
    • Pick a location that is by the band so that if you make any scratches they will be less obvious when you are done. Place the screwdriver between the frame and the back cover. Gently tap the back of the screwdriver with a small hammer or whatever you have around. Do not use your hand!
  3. Armitron Base Metal Bezel Stainless Steel Back Battery Replacement, Open: step 3, image 1 of 1
    • Remove back.
  4. Armitron Base Metal Bezel Stainless Steel Back Battery Replacement, Pry: step 4, image 1 of 1
    • While securing the inside of the watch with a finger or thumb, gently pry out the battery.
  5. Armitron Base Metal Bezel Stainless Steel Back Battery Replacement, Replace: step 5, image 1 of 1
    • Insert a new battery. Line up the cover in the correct position. Keep the notch lined up with the winding screw. Secure the back to the frame by applying equal pressure and squeezing the two parts together.
2 other people completed this guide.
Matthew Radice
182 Reputation
1 Guide authored
One Comment
Ser magkanu po ang base metal vezel stailess steel v353-6AOO RO magkanu po model naganyan
reynaldo factor - Reply
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 137
All Time: 12,061
