ArmorAll AA255 Motor Replacement
  1. ArmorAll AA255 Motor Replacement, Lower Motor Housing: step 1, image 1 of 1
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Motor Replacement: step 2, image 1 of 1
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Motor Replacement: step 3, image 1 of 1
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Motor Replacement: step 4, image 1 of 2 ArmorAll AA255 Motor Replacement: step 4, image 2 of 2
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Motor Replacement, Motor: step 5, image 1 of 3 ArmorAll AA255 Motor Replacement, Motor: step 5, image 2 of 3 ArmorAll AA255 Motor Replacement, Motor: step 5, image 3 of 3
    • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
    • Pull the ball cage to remove it from the main housing.
  6. ArmorAll AA255 Motor Replacement: step 6, image 1 of 3 ArmorAll AA255 Motor Replacement: step 6, image 2 of 3 ArmorAll AA255 Motor Replacement: step 6, image 3 of 3
    • Remove one 13mm nut from the main housing.
    • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
    • Remove metal ring from the main housing.
    • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
  7. ArmorAll AA255 Motor Replacement: step 7, image 1 of 3 ArmorAll AA255 Motor Replacement: step 7, image 2 of 3 ArmorAll AA255 Motor Replacement: step 7, image 3 of 3
    • Turn the whole body over to separate motor cover.
    • Use a PH2 screwdriver to remove the five 15mm screw.
    • Remove the white power wire from the motor cover.
    • Pull the motor cover from the main housing.
  8. ArmorAll AA255 Motor Replacement: step 8, image 1 of 2 ArmorAll AA255 Motor Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • You may need to mark the color of the wire on each terminal for reassembly.
  9. ArmorAll AA255 Motor Replacement: step 9, image 1 of 2 ArmorAll AA255 Motor Replacement: step 9, image 2 of 2
    • The motor is ready for replacement. Pull the motor to separate.
6 other people completed this guide.
YeaJun Yoo
302 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Spring 2016 Member of IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 Members
4 Guides authored
4 Comments
What is the motor product no? It will help if there is a link to buy the motor
Austin K - Reply
Medida de los carboncitos que lleva el motor?
SERVANDO ARTEA FAVELA - Reply
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
erikazavala2882 - Reply
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
A Anderson - Reply
Past 24 Hours: 7
Past 7 Days: 17
Past 30 Days: 62
All Time: 4,149
