ArmorAll AA255 Switch Replacement
  1. ArmorAll AA255 Switch Replacement, Lower Motor Housing: step 1, image 1 of 1
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Switch Replacement: step 2, image 1 of 1
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Switch Replacement: step 3, image 1 of 1
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Switch Replacement: step 4, image 1 of 2 ArmorAll AA255 Switch Replacement: step 4, image 2 of 2
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Switch Replacement, Switch: step 5, image 1 of 1
    • Using a PH2 screw head, unscrew the two 15mm screws as shown.
  6. ArmorAll AA255 Switch Replacement: step 6, image 1 of 3 ArmorAll AA255 Switch Replacement: step 6, image 2 of 3 ArmorAll AA255 Switch Replacement: step 6, image 3 of 3
    • Pull the black handle.
    • Using a PH2 screwdriver, unscrew the single 12mm screw shown.
  7. ArmorAll AA255 Switch Replacement: step 7, image 1 of 2 ArmorAll AA255 Switch Replacement: step 7, image 2 of 2
    • Use the blue opening tool to open up the black handle.
  8. ArmorAll AA255 Switch Replacement: step 8, image 1 of 2 ArmorAll AA255 Switch Replacement: step 8, image 2 of 2
    • Using your fingers, gently take out the black cords.
    • Careful to not break the black cords.
  9. ArmorAll AA255 Switch Replacement: step 9, image 1 of 2 ArmorAll AA255 Switch Replacement: step 9, image 2 of 2
    • Using the spudger, take out the switch. Do this by pushing the spudger against the switch on both sides as shown and then pull the switch out.
  10. ArmorAll AA255 Switch Replacement: step 10, image 1 of 1
    • Replace the switch shown.
2 other people completed this guide.
Renzo La Rosa
224 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Spring 2016 Member of IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 Members
4 Guides authored
One Comment
Any idea where to find a replacement switch? I did not see one on Amazon or eBay.
Mitchell Taylor - Reply
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 35
All Time: 2,627
