Arnova 7K G3 Camera Replacement
  1. Arnova 7K G3 Camera Replacement, Rear Cover: step 1, image 1 of 3 Arnova 7K G3 Camera Replacement, Rear Cover: step 1, image 2 of 3 Arnova 7K G3 Camera Replacement, Rear Cover: step 1, image 3 of 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Arnova 7K G3 Camera Replacement: step 2, image 1 of 2 Arnova 7K G3 Camera Replacement: step 2, image 2 of 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Arnova 7K G3 Camera Replacement: step 3, image 1 of 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 4, image 1 of 2 Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Arnova 7K G3 Camera Replacement: step 5, image 1 of 3 Arnova 7K G3 Camera Replacement: step 5, image 2 of 3 Arnova 7K G3 Camera Replacement: step 5, image 3 of 3
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Arnova 7K G3 Camera Replacement: step 6, image 1 of 3 Arnova 7K G3 Camera Replacement: step 6, image 2 of 3 Arnova 7K G3 Camera Replacement: step 6, image 3 of 3
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
  7. Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Motherboard: step 7, image 1 of 1
    • Remove the two Phillips #00 screws from the motherboard.
  8. Arnova 7K G3 Camera Replacement: step 8, image 1 of 1
    • Gently lift up the motherboard and reorient it in a more efficient manner in order to locate the desired components.
  9. Arnova 7K G3 Camera Replacement, Camera: step 9, image 1 of 2 Arnova 7K G3 Camera Replacement, Camera: step 9, image 2 of 2
    • Locate the camera and camera ribbon connection on the backside of the motherboard.
  10. Arnova 7K G3 Camera Replacement: step 10, image 1 of 2 Arnova 7K G3 Camera Replacement: step 10, image 2 of 2
    Buy
    • Unlock the camera ribbon connector clip using a pair of tweezers.
  11. Arnova 7K G3 Camera Replacement: step 11, image 1 of 3 Arnova 7K G3 Camera Replacement: step 11, image 2 of 3 Arnova 7K G3 Camera Replacement: step 11, image 3 of 3
    • Gently by hand, remove the camera and its ribbon by pulling the camera away from the motherboard.
    • There is adhesive foam on the backside of the camera that may cause some difficulty when removing the camera.
Kue
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 340
