Astak Mole Motor Replacement
  1. Astak Mole  Motor Replacement, Lower Case: step 1, image 1 of 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole  Motor Replacement: step 2, image 1 of 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole  Motor Replacement: step 3, image 1 of 1
    • Remove the SD card.
  4. Astak Mole  Motor Replacement: step 4, image 1 of 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole  Motor Replacement: step 5, image 1 of 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole  Motor Replacement, Electric Motor Assembly: step 6, image 1 of 1
    • Unscrew both screws using the Phillips head (PH1) screw bit and set aside for reassembly
    • Screw Measurements: Length: 7.1mm
    • The motor should be free of its housing and only be attached to the motherboard by its wires.
  7. Astak Mole  Motor Replacement: step 7, image 1 of 1
    • Sever motor connection to motherboard and remove wire carefully.
    • Optional: Use electrical adhesive to prevent dislodging of new wired connection.
Andrew Birch
204 Reputation
2 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2016 Member of USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 538
