Astak Mole Antenna Replacement
  1. Astak Mole Antenna Replacement, Lower Case: step 1, image 1 of 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Antenna Replacement: step 2, image 1 of 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Antenna Replacement: step 3, image 1 of 1
    • Remove the SD card.
  4. Astak Mole Antenna Replacement: step 4, image 1 of 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Antenna Replacement: step 5, image 1 of 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Antenna Replacement, Antenna: step 6, image 1 of 2 Astak Mole Antenna Replacement, Antenna: step 6, image 2 of 2
    • Unscrew the antenna in a counter-clockwise rotation.
  7. Astak Mole Antenna Replacement: step 7, image 1 of 1
    • Take out the screw holding the antenna wire with the PH1 size Phillips head bit.
    • Screw length: 5.3mm
  8. Astak Mole Antenna Replacement: step 8, image 1 of 1
    • Gently pry open the circuit board attached to the antenna wire using a metal spudger.
  9. Astak Mole Antenna Replacement: step 9, image 1 of 1
    • Remove the antenna female end from the motherboard.
Meshari Alkhelaiwi
143 Reputation
1 Guide authored
USF Tampa, Team 2-2, Blackwell Fall 2016 Member of USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 475
