Astak Mole Camera Head Replacement
  1. Astak Mole Camera Head Replacement, Lower Case: step 1, image 1 of 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Camera Head Replacement: step 2, image 1 of 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Camera Head Replacement: step 3, image 1 of 1
    • Remove the SD card.
  4. Astak Mole Camera Head Replacement: step 4, image 1 of 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Camera Head Replacement: step 5, image 1 of 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Camera Head Replacement, Camera Head: step 6, image 1 of 1
    • Unscrew the three screws connecting the base to the camera head with the PH1 size Phillips head bit.
    • Screw measurements: Length=7.0mm.
    • The third screw can be exposed by rotating the camera head.
    • Do not force the camera head farther than it will allow you.
  7. Astak Mole Camera Head Replacement: step 7, image 1 of 1
    • Unscrew indicated Phillips head screws using the PH1 Phillips head bit to free wires.
    • Screw measurements: Length=3.5mm
  8. Astak Mole Camera Head Replacement: step 8, image 1 of 3 Astak Mole Camera Head Replacement: step 8, image 2 of 3 Astak Mole Camera Head Replacement: step 8, image 3 of 3
    • Separate the three indicated outputs from the motherboard with metal spudger.
    • There is electrical adhesive on the output. This can be easily separated with the metal spudger.
  9. Astak Mole Camera Head Replacement: step 9, image 1 of 1
    • Separate the wire from CPU by cutting adhesive with metal spudger.
    • It is advised to reapply adhesive to wired connections during reassembly, and to re-attach wires to CPU to prevent disconnection and loose wires inside device.
    • Be careful not to damage the CPU in the process. This is not a wired connection.
Bryan
104 Reputation
1 Guide authored
USF Tampa, Team 2-2, Blackwell Fall 2016 Member of USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 712
