Astak Mole Microphone Replacement
  1. Astak Mole Microphone  Replacement, Lower Case: step 1, image 1 of 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Microphone  Replacement: step 2, image 1 of 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Microphone  Replacement: step 3, image 1 of 1
    • Remove the SD card.
  4. Astak Mole Microphone  Replacement: step 4, image 1 of 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Microphone  Replacement: step 5, image 1 of 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Microphone  Replacement, Microphone: step 6, image 1 of 1
    • Remove microphone from its holder on the bottom section of the casing.
  7. Astak Mole Microphone  Replacement: step 7, image 1 of 1
    • Access microphone and assess damage.
  8. Astak Mole Microphone  Replacement: step 8, image 1 of 1
    • Remove microphone input with metal spudger. Be sure to sever electrical adhesive in order to separate input and output.
    • It is advised to re-apply adhesive to the cable once the new microphone cable is replaced.
Joseph Bello
228 Reputation
2 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2016 Member of USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 302
