Astro A20 Frame Replacement
  1. Astro A20  Frame Replacement, Frame: step 1, image 1 of 1
    • Place your hand on the back of the speaker.
  2. Astro A20  Frame Replacement: step 2, image 1 of 2 Astro A20  Frame Replacement: step 2, image 2 of 2
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
  3. Astro A20  Frame Replacement: step 3, image 1 of 1
    • Lift the speaker.
    • Disconnect the white connector from the device.
    • Remove the wires connecting the frame shown by the yellow square.
    • Pull the black cord through the hole shown by the blue arrow.
  4. Astro A20  Frame Replacement: step 4, image 1 of 1
    • Find the top 7mm J1 JIS head screws.
    • Remove the two 7mm J1 JIS head screws with a J1 screwdriver bit connected to a 60mm extension.
    • Pull the black cord through the frame.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 3,067
